Thoughts on the auto shift lever
Old 03-20-08, 10:32 AM
GS4VIPbOSS
GS4VIPbOSS's Avatar
gated shifter - problem solved
Old 03-20-08, 10:43 AM
shaitaan
shaitaan's Avatar
Originally Posted by AutoCoutureSC
SC3 conversion simple. SC4 = the suxors
that's what im about to do sc4 gated shifter conversion.
I'm hoping I can bug one of you for help
Old 03-23-08, 11:37 PM
GS4VIPbOSS
GS4VIPbOSS's Avatar
if you have the gated -put it in you will love it and it is not hard to install if you follow advice given in this forum.
Old 03-23-08, 11:42 PM
JesLet
JesLet's Avatar
I have a gated shifter from 99 SC400 and I'm installing it into my 92 SC400... How hard could that be?
Old 03-24-08, 08:06 AM
chuggernot
chuggernot's Avatar
Originally Posted by CLRH2O
Just a heads up on the gates shifter conversion... it is NOT an easy process and requires quite a large number of hidden parts, processes and costs to get working correctly. Including but not limited to custom work for the handle mounted button that you will loose in the process. If your considering doing this job search A LOT first and be well prepared both mentally and materially before you start.
can you give the rest of us a heads up on what the hard part of this is? what parts should we be paying attention to and what hidden costs are going to pop up. do you have pics of yours we can see? i would be interested in trying this and would like yours (and anyone else who's done this) knowledge on how to get it done right and with the least amount of hassle.
Old 03-25-08, 03:07 PM
jm94tt
jm94tt's Avatar
Here's another alternative...........
Old 03-25-08, 03:14 PM
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
More information on above mod? ^ I like it more than stock.
Old 03-25-08, 03:21 PM
jm94tt
jm94tt's Avatar
a little cutting and welding Works and fits like stock. Only downside is that the cover for the screws is smaller than the ***** so there is a small gap around the base.
Old 03-25-08, 03:34 PM
jm94tt
jm94tt's Avatar
Basically, what I did was cut and reweld the supra shifter assembly to match the angle and center of the SC's, as well as having to extend it and the O/D button rod .75" to clear the "gate". Then I swapped it into the SC shifter assembly and adjusted the trans linkage.
Old 03-25-08, 03:47 PM
GS4VIPbOSS
GS4VIPbOSS's Avatar
Not too hard to do if you follow advice on these forums took me 3 hours. Requires a complete gated assembly and some know how- hardest part is correctly attaching the shifter to the transmission shifter mechanism- be prepared to get under your car. I heard a lot of gated shifter mystery tell I put it in, and again wasnt too bad...
Old 03-26-08, 01:40 AM
JesLet
JesLet's Avatar
Do you have info on how to wire it?
Old 03-26-08, 07:48 AM
TheRonTom3
TheRonTom3's Avatar
Thats the grey area is the wiring. There is a good write up on here about the wring but the pictures for it are really blurry. I am considering gated shifter as well so this information would be a plus. I was always thinking I could just wait till I explode my transmission after i go 315's in the rear with LSd and forced indcution and then sawp in a 99+ sc4 tranny.
Leechmon
05-09-18 10:43 PM
shiny250
02-25-10 12:08 AM
Papajorgio
SC- 1st Gen (1992-2000)
02-19-10 01:29 AM
Frydryce
01-04-06 09:11 PM
Quick Reply: Thoughts on the auto shift lever
