Any Magnaflow mufflers similair to these?
Are there any Magnaflow mufflers similar to Greddy MX exhaust? Every Magnaflow muffler I have seen on a SC does not fit seem to fit as well as the Greddy, the muffler is large, and the tips are in the center of the muffler. Does Magnaflow make something similair to these?
I know about the Tanabe exhaust, but that is way too expensive.
I'm using Magnaflow model 14236 mufflers on my car. They're 2.5inch diameter pipe fittings and I run a single 3 inch midpipe that splits to dual 2.5 inch. These Maganflow mufflers truly met my criteria for quiet, but free flowing, while still having a nice tone. Everyone that has ridden in my car has always favorably commented on the exhaust tone. I'm considering going dual 3inch diameter to reap some flow benefits at high boost if someone buys my current exhaust setup . Either way, I'd just get the same style Magnaflows, but in the 3 inch diameter form. They're good mufflers.
![](https://i19.photobucket.com/albums/b188/dejacky/Exhaust11.jpg)
Retired
magnaflow 14827 -
![](http://www.magnaflow.com/02product/parts/14827.jpg)
http://www.magnaflow.com/02product/s...ne=main&id=769
magnaflow 14850 -
![](http://www.magnaflow.com/02product/parts/14850.jpg)
http://www.magnaflow.com/02product/s...ne=main&id=794
magnaflow 14850 -
Apexi makes a universal WS muffler with offsetted tips that look similar to the Greddy MX.
http://www.apexi-usa.com/product_exh...=177&pageNum=1
My next magnaflow muffler will be the 14239 model so it's compatible with the dual 3inch setup. My setup only looks like it hangs low because of the angle I took the picture. It's pretty close to the heatshield above the muffler, so I don't think it can be pushed much higher. I'll try to find some more pics and edit this post to show it. On a weekend, I re-measure the distance between the muffler and the above heat-shield just to confirm.
you probably can't get those magnaflow's as flush to the bumper, if you look at the mufflers the greddy mx's are alot smaller, pretty thin..
i'm guessing the tips are 3"
well this is the pics i found for it online...
the walls of the tips look thin..
thread i found while looking for it
http://www.lextreme.com/greddysc.html
![](http://i43.photobucket.com/albums/e358/nugooyah/greddymxsc3002.jpg)
![](http://i43.photobucket.com/albums/e358/nugooyah/greddymxsc300.jpg)
