How many quarts of ATF do I need for SC300
Old 03-23-08, 01:57 PM
phongminh
phongminh's Avatar
Default How many quarts of ATF do I need for SC300
I have 1995 Lexus SC 300. I am just drain Automatic Transmission Fuild, just wonder how many quarts of ATF do I need to put it in. I read the manual and it said 1.7 quarts but my friend 10 yrs machanic said is 3.5 to 4 quart. Can someone tell me.
QUENSc300 (12-14-22)
Old 03-23-08, 07:18 PM
slappy96
slappy96's Avatar
About 3 for me on a drain and refill. 2.9 to be exact. Just don't overfill. Put about 2-2.5 then drive it approx 10 miles. Come back run it through all of the gears. Put it in neutral with the engine running and check the hot level on the dipstick. That should be accurate. Don't recommend adding room temp ATF while it's hot in the car though. Wait till the car trans cools down.
Old 10-08-14, 09:50 PM
Rezist89
Rezist89's Avatar
Bump I'm also gonna be dumping the old fluid for new where is the best place to order the fluid and which one also how many quarts do I need 1995 sc auto thanks
Old 10-10-14, 02:03 PM
daM00ke
daM00ke's Avatar
When i did my Tranny Flush last week i ended up using Valvoline tranny fluid. It was ok with the type t-IV fluid we need. With a drain and refill i only got maybe 2.5 quarts of fluid. Put back right about the same amount and checked dipstick at hot temp. I will be redoing a drain and fill every few weeks to get all old fluid out because majority of fluid sits in torque converter anyways. Dont recommend doing a full flush of the 7-8 quarts at once.
ECUgs430
11-18-23 12:27 PM
lexslexus
03-30-18 01:56 PM
cdvmagic
Maintenance
01-31-07 11:44 AM
HotBoy
Maintenance
12-30-03 09:09 PM
Quick Reply: How many quarts of ATF do I need for SC300
