Clutch? What is wrong?
Old 03-27-08, 09:57 PM
LCSC
LCSC's Avatar
Default Clutch? What is wrong?
Ok to keep it short sometimes my clutch doesn't fully engage. Sometimes (more often than not) I can't get it into gear until I shut the car off and then I have to restart it. I bled the clutch and I didn't help. FYI about 6 months ago I put a centerforce DF Clutch (I don't think this is relevant but I'm hoping you all know something I don't). Is there a way I can tell if it is the master cylinder or the slave? The slave doesn't appear to be leaking and I can't see much of the master.
Thanks for any help.
Old 03-27-08, 10:33 PM
fwynn
fwynn's Avatar
try changing the Tranny fluid? usually its clutch AND tranny i think..
use Royal purple :]
Old 03-27-08, 11:17 PM
Baoser
Baoser's Avatar
check to see if ur pressure plate is damaged?
Old 03-27-08, 11:27 PM
JesLet
JesLet's Avatar
It has to be the clutch slave.. give it a try.
Old 03-28-08, 03:05 AM
LCSC
LCSC's Avatar
use Royal purple :]
I have pretty fresh amsoil in there right now. Remember that the car will go right into gear if the engine is shut off and it should be the same when the clutch in engaged.
That seems like a lot of work just to see. I don't see how this could be the problem from what I described but please explain.
I'm thinking the same thing but what makes you think that it's the slave over the master is it just that it is cheaper.
Thanks
Old 03-28-08, 04:47 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
92SoCal
04-25-13 09:06 AM
celiman05
03-01-10 09:10 PM
pnyboy27
13
08-04-08 01:57 AM
dejacky
06-15-08 09:23 AM
Mr.Machine
02-17-07 10:09 PM
Quick Reply: Clutch? What is wrong?
