Gated shifter
For those of you have a gated shifter on pre-98... where should I tap the positive and negative wires for the lamp.
I also need where to tap the #2 wire.
Does anyone here know? I can't find the diagram or schematic for 98 gated shifter.
I got everything working except for those above. I just followed the diagram below.
![](https://www.clublexus.com/gallery/data/500/NewShifter.jpg)
or you could tap in the original illum wires that plugged into the bottom of the old shifter cover where the letters light up. Don't quote me but I think they were the bottom left two wires with the same plug orientation you have shown. Clear as mud right
Thanks Gazi,
But those wires I posted are from the harness.
I made my diagram:
![](http://i235.photobucket.com/albums/ee42/enyce18/HARNESSLAMP.jpg?t=1206726271)
According to gadgetsc's diagram, the positive wire is Gray and negative is Blue... I hooked those up to the ashtray and still won't light up even the ignition is on. The parking lights are on too.
I made my diagram:
