Wiring diagram to install gated shifter into pre-98 SC
04-01-08, 12:21 PM
I'm lovin' the O/D on "4" gear... it kicks so bad on the freeway!
04-01-08, 12:32 PM
NOTE:
SC400 gated shifter is different from SC300 gated shifter.
The difference is the gear selection.... but might be the same wiring.
Mine is from 98 SC400.
SC300 gated shifter on SC400 non gated will also work.
04-01-08, 12:59 PM
SC3 and SC4 should have the same wiring. Also, if you have a SC3, you can use your existing shift linkage from what i recall.
04-01-08, 01:05 PM
Quote:
Originally Posted by
AutoCoutureSC
Do you have SC300? Do you have to modify the shift linkage?
04-01-08, 01:41 PM
where did you tap for the speed sensor connection?
04-01-08, 01:43 PM
TheRonTom3
There 4 locations, pick 1:
ECU
Cluster
Transmission
Driver side kick panel, lower orange harness.
Look for a PINK wire.
04-01-08, 01:45 PM
JesLet
NOTE:
oh man. i think mine is from an SC3, and im gonna try to make it work on an sc4.....
04-01-08, 01:47 PM
shaitaan
Don't worry it will still fit.
04-01-08, 01:49 PM
You need longer bolts to attach the gated shifter to the chassis. Autozone has a set... bring your old one and match it. You need at least 1 inch longer bolts.
04-01-08, 02:35 PM
JesLet
i have an sc4. i believe the sc3 you can use your old shift linkage. I bought a new one from the dealer, but it was no good for the sc4 application.
04-01-08, 02:36 PM
JesLet
or you can request whomever you're buying the gated shifter from give you bolts as well. dealer sells them cheap.
04-01-08, 02:40 PM
I got my gated shifter from CA for $85 shipped, shifter assembly and bezel.
Good deal?
04-02-08, 04:25 PM
My SC is a stick, but this sure does add alot of luxury to an SC
04-08-08, 11:00 AM
where and how mauch can you pick up a gated shifter for?
04-08-08, 11:03 AM
hit up the classifieds there are 2 sc300s getting parted out right now
