Wiring diagram to install gated shifter into pre-98 SC
#31
Yo, i got a question. I didn't see if you did this on a pre 98 But i did read about you talking about. Since the pre's have 3 gear mods on the shifter L-2-D. Will this work ?or does it a kit convert it ...
#33
That cheap? wow, you got a steal. Most of the ones I've been looking at were $150-250, and that didn't even include the bezel or the shifter ****. Where did you find yours? I've been searching eBay and craigslist.
#34
#37
So for the SC300 gated, there's no 4th gear, is that correct? So what do you do with OD? That has to change the wiring I would guess. Thanks for any insight - trying to talk myself in to spending the money to do this but I want to be sure to buy the right things.
#42
my shifter as follows. D= overdrive on. 3=overdrive off . 2=overdrive off. 1=overdrive off .overdrive is only engaged when in D and and all other gears works as it should. The switch was customized for it to work like this .here is a pic of the sc3 gated shifter in my sc.
![Name: Picture134.jpg
Size: 71.5 KB](https://www.clublexus.com/forums/attachments/performance-and-maintenance/440235d1501408496-wiring-diagram-to-install-gated-shifter-into-pre-98-sc-picture134.jpg)
