2jzgte swap list please add if i'm missing things and make corrections.
Old 04-02-08, 10:40 PM
Cleanshots
Cleanshots's Avatar
Exclamation 2jzgte swap list please add if i'm missing things and make corrections.
1. i have the aristo 2jzgte
2. i have the harness and ecu
3. im going to get the harness made.
4. im going to use the sc300 ac system.
5. to use the aristo PS i need custom line.
5. i need supra mk4 motor mounts, i still dont know exactly what i need.. do i need brackets or just the mounts or wat the heck?!??!? can i sue sc300 brackets and supra mounts or wat?
6. need to swap oil pans, weld flange thing for oil return and use sc300 water pump pulley
7. i also need supra mk4 TT water pump.
8. ill use aristo SMIC will be tricky bu i hear you can get it to work... until i have more money for FMIC
please modify or add to the list, thanks every one.
Old 07-01-08, 09:33 AM
scdriver1
scdriver1's Avatar
I'm doing the same swap and heres what the shop said I needed among the items you listed:
fuel cut defender
throttle cable (TT)
O2 simulator(negotiable)
ignitor
resistor
EGR block off plates
Old 07-01-08, 10:10 AM
Cleanshots
Cleanshots's Avatar
someone buy my 2jzgte engine set
Old 07-05-08, 04:32 PM
mhlamin
mhlamin's Avatar
why are you not completing this swap>
does your 2.5k include a tranny?
Old 07-05-08, 06:33 PM
thaimonkee
thaimonkee's Avatar
you can use the sc motor mount and brakets. i used them for my swap. as for resistor pack its only necessary if you plan on running usdm 550 injectors or any low impedance injectors.
2jdeemo
07-03-14 01:39 PM
4thHorsemn
SC- 1st Gen (1992-2000)
41
08-22-13 10:00 PM
96blksc300
23
07-09-12 03:28 AM
Hydro
02-13-11 07:44 AM
rsos1
09-04-09 04:37 PM
Quick Reply: 2jzgte swap list please add if i'm missing things and make corrections.
