HELP: Check engine light just came on! what could it be? how 2 reset?
Old 04-07-08, 12:40 AM
sc400 2nv
sc400 2nv's Avatar
Default HELP: Check engine light just came on! what could it be? how 2 reset?
my check engine light just turned on. the car is running fine. what could have caused it to turn on. its a 98 sc4 w 200k....maintenance reminder??????
how do u reset it or turn it off???? im cheap and was thinking of just pulling out the bulb... any other solutions???
thanks guys
Old 04-07-08, 04:25 AM
TheMole
TheMole's Avatar
If its the check engine light, use an obd2 reader to scan the code. If its the maintenance light (MAINT), it will light up at certain mileage intervals.
Old 04-07-08, 06:02 AM
RyanV
RyanV's Avatar
have fun
http://www.troublecodes.net/Lexus/
Old 04-07-08, 07:00 AM
Lextreme
Lextreme's Avatar
You gotta find out what cause the CEL. Simply resetting WON'T work. The simpliest way would be unplugging the battery, but that is just temporary.
Old 04-07-08, 07:48 AM
StiCk3
StiCk3's Avatar
thanks guys
Whatever it is, dont reset the computer until the issue is resolved. Take it to Autozone, they scan the ECU trouble codes for free so then you can explain to us what the REAL problem is. If you reset the ecu or ignore it, you could cause serious damage to you're engine. Don't go ghetto, not going to help.
Old 04-08-08, 04:35 AM
sc400 2nv
sc400 2nv's Avatar
bump bump! where is this moved to?
Old 04-08-08, 04:36 AM
sc400 2nv
sc400 2nv's Avatar
^^^^^ never mind.. thanks guys!
Old 04-09-08, 05:03 AM
sc400 2nv
sc400 2nv's Avatar
the check engine light just turned back off after a day.... it fixed itself! haahaa =)
What could have caused it to suddenly turn on for a little bit?????????????
Old 04-09-08, 05:50 AM
Dx3
Dx3's Avatar
You are showing a soft code which will go on and off. Could be anything - O2 sensor going bad, etc etc.
You are in an OBDII car - most people would kill to have a CEL on an OBDII car than and OBDI.
Go to Autozone or your local parts store and ask them to pull a code for you. They do it for free, it takes 30 seconds, and it will tell you exactly what the problem is.
Now explain to me why in the world you would pull the bulb. Not only is this a terrible idea that serves no merit, it would also take 10 times as long to do as going to get your code scanned.
On the same basis, if you woke up one morning and had a gaping hole in your leg, would you go get it checked out or would you stick a band aid over it and hope it miraculously goes away?
Jonny
kchat99
05-23-19 06:26 AM
Fatbarney
GS F (2016-present)
12-17-18 11:11 PM
Altec914
07-17-08 06:24 PM
cyrus951
GS - 1st Gen (1993-1997)
03-02-08 07:18 AM
esucaris1
06-10-07 09:18 PM
Quick Reply: HELP: Check engine light just came on! what could it be? how 2 reset?
