will these motor mounts fit our car?
http://www.injectedperformance.com/e...t.aspx?ID=1455
i am planning on getting new motor mounts when i do the swap, will these fit fine?
already got the swap done from previous owner, but according to him the driver side engine mount is busted...
so will this kit fit the sc300 with 1jz already?
I don't have the advantage of having a pair of the shorter Supra engine mounts (the JDM engine came with only one side) --- so what is the best drop-in replacement mount to use on a set of the original 1992 SC300 aluminum mount brackets?
My drivers side is torn half-way through, the passenger side torn 75%.
The car has 172K on it-- so I'm assuming this is just a normal service life limit. We were careful when pulling the engine to make sure we did not strain the mounts with any bending motion.
Thanks!
Thanks!
Thanks!
Thanks!
white96SC
Performance & Maintenance
07-11-10 05:40 AM
DroppedGS
GS - 1st Gen (1993-1997)
12-30-03 12:33 PM
