Blown HG on a 92 5-spd -- fixing it right
yeah-- did that too-- when I had the block all the way down to just the pistons and rods-- crankshaft out. I used a pressure washer that pulled de-greaser into the air stream and flushed all the oil galleys out until I saw clear fluid running out of all the oil feed ports to the main bearing saddles.
Pic is at the beginning of a 3 hr process before we had it sitting on the all the mounts. I should have left that drivers side motor mount off!
Saturday-- is wiring and detail work, but I'm determined to have this car running by Saturday afternoon.
Good thing I took a bunch of pics of the engine bay before I took the engine out. There are a ton of little brackets and vacuum lines, but I used colored sticky page markers to color code what line went where.
Good idea. Let me know if you need help with anything. If you are close and run into issues I can stop by. If you want I can PM you my number. Time for things to work right! Good Luck.
Ian
Ian
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
I went with Royal Purple Syncromax in the gearbox, and this morning drained the Havoline oil and pulled the filter that I had on the rebuild for about a hour of idling time last night. That oil had the combo of Red Line assembly lube, vasoline--from the oil pump pack, and Magic Marvel Mystery Oil--to free up the piston rings and help the valve guides along. It came out dark with only the one hour of run time.
I filled it with Royal Purple 10W30 and fitted a OEM oil filter I bought at the dealer.
The only issue is a noise from the clutch release bearing. I put a new one in with a new pilot bearing and also a new clutch disk. But it sounds like the pressure plate is still lightly contacting the pressure plate fingers even when fully released. I can't remember if the slave cylinder rod has any length adjustment to it. But if it does I may try to shorten it just a tad. The noise immediately goes away when just barely loading the release bearing with the pedal. I am worried that with the release bearing rotating all the time, the life will be shortened a lot.
GRAND_LS 4
Performance & Maintenance
04-11-08 03:22 PM
ProfesrLEX
GS - 1st Gen (1993-1997)
07-11-07 04:26 PM
