2 quick questions aristo gte swap
Old 04-19-08, 05:05 PM
Cleanshots
Cleanshots's Avatar
Default 2 quick questions aristo gte swap
its going into a sc300 will the stock fuel lines work and for the ac which pump do i use, gte pump with ge ac lines or just swap the pump and use everything from the ge?
Old 04-19-08, 11:39 PM
redhanded7
redhanded7's Avatar
the ge pump should bolt up to the gte motor, and you use the ge lines. thats what i did and everything bolted up fine.
em1turbo
Build Threads
06-13-17 08:14 PM
99 GS3
02-04-17 09:54 AM
rickytsui
10-20-12 09:24 AM
phamxOC
10-18-11 05:22 AM
Quick Reply: 2 quick questions aristo gte swap
