2JZGE crankshaft journals
hello!
Can someone please post the main journal and rod journal std. diameters (in English units) for me?
Also-- a crankshaft "end-float" spec would be appreciated.
I've decided to fit new bearings to this JDM engine I bought, and I want to mic the journals before I buy bearings to make sure they are standard size.
If anyone has had better luck with one brand of bearing (i.e. Clevite 77) over another, that advice would also be appreciated.
This engine is NA, and will probably stay that way as a daily driver.
Thanks
M.
1992 SC300 5-spd.
Thanks
M.
1992 SC300 5-spd.
Clevite 77's are now some reboxed junk with clevites name on them. Search on supraforums and i'm sure you will find what all the high hp guys are using in terms of bearings.
joshthorsc
Performance & Maintenance
05-17-06 08:37 PM
