1998 - 2000 SC400 Differential Ratio
3.27
The 98-00 SC400 used the same 5AT that ran in the GS400. Both used a 3.7 rear end that is compatible with the same LSD units as the 92-97 SC rear ends.
I am presonally putting a TRD LSD onto a 98-00 SC400 rear end with a 3.27 ratio for the 5MT project I have in the works.
Location: Sideways on the Yellow Brick Road! < Thats KS!
92-97 SC300
6 cyl, AT (4.27 ratio)
6 cyl, MT (4.08 ratio)
98-00 SC300
92-97 SC400
8 cyl (3.92 ratio)
98-00 SC400
8 cyl (3.266 ratio)
92-96 MKIV Supra
w/o turbo; (4.27 ratio) Limited Slip
w/turbo, MT (3.133 ratio) Limited Slip
w/turbo, AT (3.769 ratio) Limited Slip
97-98 MKIV Supra
w/o turbo; (4.08 ratio) Limited Slip
98-00 SC300
92-97 SC400
8 cyl (3.92 ratio)
98-00 SC400
8 cyl (3.266 ratio)
92-96 MKIV Supra
97-98 MKIV Supra
92-97 SC300
98-00 SC300
92-97 SC400
8 cyl (3.92 ratio)
98-00 SC400
8 cyl (3.266 ratio)
92-96 MKIV Supra
97-98 MKIV Supra
98-00 SC300
92-97 SC400
8 cyl (3.92 ratio)
98-00 SC400
8 cyl (3.266 ratio)
92-96 MKIV Supra
97-98 MKIV Supra
If you are in need of one, Gazi (Member name: Aliga) sells them for $300 shipped...which is not a bad deal for something that is in relatively limited supply.
