Installed new exhaust, now have some hesitation. WTF!
So yeah, the hesitation is back and it worse than ever. Still no check engine light, but it feels like it's "missing". From a dead stop it sputters like a beeotch and in low RPM situations it will sputter too. Does this sound like perhaps a lack of backpressure? It ran OK for a couple weeks and now it's nonstop after today. I'm going to clean my sensors and check my plugs and rotors although they've got like 10k on them. Maybe a fuel filter? It started acting up the first time I drove it after I put the exhaust on though, just a coincidence? Anyone with a true dual setup, I would love to hear if you've experienced any issues.
Location: Sideways on the Yellow Brick Road! < Thats KS!
I am thinking you really should have a cat between the two 02 sensors on OBDII system. Mine worked perfectly when I was NA, It really sounds like that is the only difference between our setups.
I was told the rears only really monitor that the fronts are operating. My stock exhaust section that I pulled off only had 1 cat and it was after the O2 sensors, so that shouldn't really affect it. Did your stock setup look like this?
I'm reading more and more and it sounds like I might have a faulty coil somewhere, and it coincidentally shat the bed on the same start as when I installed the exhaust. I happen to have a "donor" SC4 in my backyard so I will see if a coil is to blame.
So, I swapped out coils. No dice, started removing wires etc... and when I got to the driver's side dist cap, it was litterally broken. WTF? Pretty wierd for that to happen, let alone having it fail on the exact same start as when I added the exhaust. What puzzles me is why didn't I get a CEL when it was missfiring? Anyways, all good now. Thanks for caring guys.
One of the coil wires was all chaunched out to. Runs like a champ now. Sounds great. Need to wait a few days again for the ECU to settle. I gave it a full reset after that sheeat.
scfou
Performance & Maintenance
01-03-10 08:54 PM
1badceli
13
01-11-06 12:30 AM
