What 1JZ manifold are you using?
#31
i seen somewhere on here, a guy connected the 2 stock manifolds and bolted up a single turbo to it. very DIY tho.
the 2 stock 1jz manifolds... since there is one for the first 3 cylinders and another for the last 3 cylinders to spool each turbo...
i saw that this guy in question, welded a log pipe to connect them together and put a single turbo in the middle
#32
www.docrace.com that's what i'm using for my 2j manifold, i was gonna have them build my 1j manifold before i sold the motor.
#35
#36
A new 'middle of the road' option. They have the Quicksilver lineup of non vvti and vvti. They even have the Quick Spool Valve 1J manifold.
This thing is gorgeous for 750
Just imagine a 1JZ with the Quick Spool setup on a T4 turbo.
![](https://ep.yimg.com/ca/I/supra_2187_24059026)
![](https://ep.yimg.com/ca/I/supra_2187_24297980)
#38
1JZ Single SC400
It's my underdstanding, it opens and closes when it receives more pressure gases from the exhaust. With one side closed, it spools up faster and the other side opens to allow the full potential of the turbo. Seen videos on Supra's with before and after installation, increased from 75-100 horsepower with these. Someone correct me if I am wrong. I also heard you really dont need this with a T4 type flange on the turbo and a T4 type manifold. This divides it already for you.
#40
We have sold hundreds of Quick Spool Valves to date and have truly put them to the test. However, in recent months there has been concern voiced about extreme conditions such as extended heat or antilag launch control. Ask and you shall receive!! We are pleased to offer the Super HD design of the Quick Spool Valve which is specifically designed for extended abuse. Torture testing will be coming shortly of this completely new blade and shaft design utilizing EDM burn technology for a 100% increase in overall strength and endurance.
99SC42
SC400 / 300 Classifieds
10-31-09 06:50 AM
2.5tsoarer
Performance & Maintenance
06-16-04 04:24 AM
