What 1JZ manifold are you using?
Old 05-06-08, 10:50 AM
BigWaveSC
BigWaveSC's Avatar
Default What 1JZ manifold are you using?
Need to get one, single T4 setup.
Old 05-06-08, 12:20 PM
evileagle
evileagle's Avatar
I too am looking for a 1J manifold. I was hoping to find some sort of cast manifold cause i don't want to deal with cracking and whatnot....
Old 05-06-08, 12:38 PM
2.5tsoarer
2.5tsoarer's Avatar
Chinafold works great for me !
Old 05-06-08, 02:17 PM
pmpdaddyt
pmpdaddyt's Avatar
ooooh perrrty!!!
Old 05-06-08, 02:22 PM
shonuff53
shonuff53's Avatar
there is a guy on here that sells the drewgo manifold (hear good things), but im also about to go the chinafold route.
Old 05-06-08, 02:56 PM
Gunnar
Gunnar's Avatar
The guy that sells the drewgo manifold is probably drewgo.
Old 05-06-08, 04:17 PM
vntperform
vntperform's Avatar
Old 05-06-08, 05:29 PM
evileagle
evileagle's Avatar
chinamanifolds blow and 100% sure will crack unless you reinforce the runners and reweld everything. I personally dont want to bother with all that and am looking into a cast unit. They are generally cheaper and MUCH stronger than any of the CHEAP tubular setups, not talking about the good tubular setups here.
Old 05-06-08, 05:38 PM
shern
shern's Avatar
Are there any cast units available for the 1JZ?
Old 05-06-08, 06:34 PM
LSEGHATCH
LSEGHATCH's Avatar
Buying a quality manifold just buys you more time, stainless with crack because it's stainless. I am running a chinamanifold and when I put in the new turbo I dye checked everything and it was fine. I'm not sure how long the previous owner had run on it.
Old 05-06-08, 06:44 PM
nate579
nate579's Avatar
Drewgo has great manifolds, have yet to hear of any cracking. Which is what I will be using when I go single.
Old 05-06-08, 07:42 PM
shern
shern's Avatar
I'm in for a group buy on the drewgo manifold.
Old 05-10-08, 09:37 PM
Zoonwen
Zoonwen's Avatar
boost logic, drewgo, and almost everyone else has their manifolds made in china. When was the last case you heard of a JZ manifold cracking ???
Old 05-10-08, 11:36 PM
joewitafro
joewitafro's Avatar
Drewgo's manifolds are made in china to his specification, their already reinforced, and have a better location for the wastegate.
Old 05-11-08, 06:05 AM
2.5tsoarer
2.5tsoarer's Avatar
exactly ! its probably even made in the same exact factory as the others. they share the same supports over the runners. yeah they are MADE to his specs which are the wastegate location and routing of the runners other than that its still made by a Chinese welder using Chinese materials.
I rather page $130 or so on ebay and weld the 2 rod supports like he did.
Quick Reply: What 1JZ manifold are you using?
