96' sc300 oil questions???
Old 05-08-08, 02:01 PM
zrs6v4
zrs6v4's Avatar
Default 96' sc300 oil questions???
I have a 1996 SC300 with 188,000 miles on it. I just bought it from the origional owner and he put castrol synthetic blend in it. I was wondering the following questions..
1- WOuld it be ok to change over to synthetic?
2- Mobil, Castrol, or Royal Purple?
3- 5w30 or 10w30
4- whats the best filter to run?
5- how much oil will I need for this car (guessing 5 quarts?
If I were to guess it would be ok to run synthetic, royal purple, 10w30, mobil filter, 5 quarts? am I on the right track... if not please explain
Old 05-08-08, 02:06 PM
vinh
vinh's Avatar
yes its ok to switch to synthetic.
I recommend Royal Purple. With that many miles you might want to go with a heavier weight.
So if i were you this is wat i would get:
Royal Purple 20w50
OEM toyota filter from dealer or mobil 1 or bosch filter
and you are correct about the 5 quarts
Old 05-08-08, 04:36 PM
zrs6v4
zrs6v4's Avatar
why that heavy of an oil?
Old 05-08-08, 04:55 PM
KAME
KAME's Avatar
I agree with the Royal Purple recommendation, but question the use of 20W50. I run RP 10W30 and swear by the stuff.
Old 05-08-08, 05:20 PM
OneJay
OneJay's Avatar
I have a 95 and use 5w-30, of course the weather in Colorado is a bit chilly sometimes. I would say if you can afford it go synthetic, and use an OEM filter. I think its the YZZ-D3. (The one for V8's) it's a little bigger and filters a bit better.
Old 05-08-08, 08:42 PM
zrs6v4
zrs6v4's Avatar
I asked a toyota builder I know and he says he runs 20w50 on his gte motor that makes 1000hp, or he said it would be good for a motor that is leaking oil or smoking otherwise just use the factory recommended..
iseeu1001
03-03-16 05:36 PM
TriniLex
10-14-14 12:08 AM
TRACKMKIII
GS - 1st Gen (1993-1997)
06-09-14 08:25 AM
Erukian
13
10-24-08 05:30 PM
vp911
RX - 1st Gen (1999-2003)
10-24-05 01:55 PM
Quick Reply: 96' sc300 oil questions???
