Supercharging a 96+ SC400
If you really want to supercharge your sc400, go with the Eaton for ease of fitting and kits are available. There will be some mods but they are simple ones.
I went with a twin screw Whipple an a motor that has over 300,000 kilometers on it, drives like a dream. My boost gauge shows 8lb easy and peeks at 10lb.
I am getting 311 hp at the wheels on stock ECU, standard injectors, a rising rate fuel reg, rebuilt trans with a shift kit, standard converter and a good exhaust.
What I really need is a good piggy back to control timing and fuel and that figure will improve significantly.
Go with an m90 and you cant go wrong, you just have to look at Scotts to see what can be done, and like Twizted said should have been done at the factory.
Location: Sideways on the Yellow Brick Road! < Thats KS!
Well, looks like I'm late to the show! I really cant say much here that has not been covered. If you still have questions I will try to anwser them.
On a seperate note; If you do decide to do it and come into the market looking for a good piggyback, look me up. I have one that is preconfigured for a SC400 OBDII and will make you a deal on it. Have all the software, and wireing diagrams simple to hook up and read to run. Currently it is pre configured to run transparent so its a plug and play deal, you can start tuning from there. PM me if you are interested. Later this winter, I may be selling a Eaton M90 flowed by magnum.
Well I'm probably not going to supercharge my car anytime soon. Maybe within the next year at least; I've got to save up the money first. I've been thinking about it more and I actually don't think I'd mind running a lower boost (probably 5-6 psi) with the power hitting later in the rev, that way I'm not guzzling fuel when under normal acceleration or cruising on the highway. I'm probably going to upgrade to a higher stall TC anyways before I go for the S/C, so that will help with low-end power. Thanks for all the info.
A few things I'd like to throw in here, although much has been covered.
1. With my V-9, I can smoke a pair of (LSD) 275's at 2200rpm. I have plenty of low end power. My stall speed is 2800rpm BTW.
2. Every form of FI has advantages and dis-advantages. As far as ease of install and low cost, I think most people here would agree that I have the least amount of money and time put into my setup.
3. Without the intercooler, I can make 10+ psi. With it I only make around 8psi. BUT on the dyno I made the same power with less boost with the intercooler. Without the intercooler, my intake temps were 180 degrees by the time I got off the dyno on a 70 degree day. With the intercooler, my intake temps were 99 degrees at the end of the session on a different 70 degree day. Seems like easy math to me.
4. My best time as of yet on an 1/8 mile track is 8.795. This puts me in the 13.6 range in the quarter. I cannot launch without spin unless I launch like my grandma would. even with the 275's.
5. As far as what any given rods can take, there are way too many factors to be able to say how much boost can be safely made. I think a hp number is probably a more accurate way to look at it. I've heard stories of engines being pushed way beyond what they "should" be able to take. Tuning is the key.
KC
KC
So what's everyone's opinions on this:
http://cgi.ebay.com/ebaymotors/Porte...m280227264254&
It's being sold buy a guy on eBay for $700. Is that a good deal, and will it work well with our cars? I was originally looking at M90 (as several of you suggested), but came across this one. Is the newer Eaton SC better? What's the main difference? Also, what will I need to make it work on my car? pulleys, remapping, etc?
When I talk about making my car faster to my friends at work they tell me "if you want a faster car, just buy one". It annoys me; there isn't a single car I would want more than my SC400. I think its the most beautifully designed car; it deserves to be much faster (I think it looks fast). Yeah 3600 lbs is heavy, but not really compared to the other high performance sports cars out there today:
Infiniti G37 = 3616-3668 lbs
BMW 335i coupe = 3759-3770 lbs
Audi S4/RS4 = 3869-3957 lbs
Audi S5 = 3593 lbs
Lexus IS-F = 3780 lbs
Audi S5 = 3593 lbs
Well now turbo is a whole different ball of wax...
Blizzy, KC, Scott, Steve, all have great set ups!! All are unique, and worth the time, effort, energy, money, heart and soul that each one of them put into their cars to get them going. I love the SC's, but I still prefer TT's more...But the TT SC400 is indeed a complicated beast to build...
I find it interesting for one to refer to sub 4 second and sub 5 second 0-60 times as not that fast. For a Street car, that is pretty damned quick. Most cars will not touch any speed below 5.5 seconds. Come on, it takes some engineering to get down to those times.
I do agree, it is easy to buy a rather quick car today, as long as one has the cash and the credit, but I still prefer to personalize my car and make it unique. Obviuosly, there are several of us on the forums that do. What fun it is...
Ryan
Now on the otherhand, if I tuned my SC to make 1000 HP and go 0-60 in under 2 secs, that would ruin it. Most women and my friends would look at that as being just overkill. Don't get me wrong, I love it that some of you guys tune your SC300s and SC400s to the extreme, but that's not really the angle I'm going for.
Anyways, thanks for the info twizted. I'm checking on eBay about those Eaton M90's. They're actually pretty cheap which is a good thing (I hope).
If you are on a budget (both KC and myself are), I would favor the centrifugal supercharger setup using the Lextreme "Fish" bracket.
While you can get an M90 for less than half of a centrifugal supercharger, the bracket to mount the M90 costs ~10 times what the Lextreme bracket does (~$200).
I think the M90 is a sweet set up. It makes the engine sound like it is a piece of brilliant alien engineering, almost like a spaceship (in my opinion). However, there is no doubt that centrifugal supercharger set up works (KC can rip 4.6s 0-60 times) and it is relatively inexpensive (~$3k with a budget minded build).
KC and I both are on a budget, and we have chosen to go with centrifugal superchargers. That should tell you something right there. Scott, Paul, Twizted, and Ryan have WAY more disposable income than we do, and their set ups reflect that.
I got my centrifugal supercharger for all of $700 (with lots of searching), and it should be able to blow up the motor if I gave the motor enough boost. It will be plenty to get me down the road faster than a G37 or a 335i.
