How I swapped an R154 into my SC400
As for your 2nd question, no. I don't really know why you don't understand the picture, its pretty self explanitory. If you use the stock cutout pattern, not only would your entire clutch pedal be slanted and cockeyed, but it would also make all of your pedals (assuming you did swap out the brake pedal) too close together, or for me anyways.
The brake pedal I will swap soon, but I am driving it now and am having no problems with clearance at all. With the way I have it setup now, they will all be evenly spaced apart.
Jon
Good Job! When I read that the auto input shaft fit, I couldnt believe it. So I went into the garage and tested it and found you were right! Are you reusing your auto dshaft? Isn't the auto dshaft too short? I saw in the pics that I can see about a cm or two of the input shaft, is that ok?
Any ways, props and I wish I had half the space that you have to work on this. Also a lift would have been great too!!
Location: Sideways on the Yellow Brick Road! < Thats KS!
Answered your question 3 times, thanks for reading.
Jon
Jon
ScottURnot,
The reason you didnt have to do any of that is because you used an SC300 master cylinder and I used an MKIII master cylinder. YOU HAVE GOT TO LEARN TO READ MAN LOL. jk. Yeah after I did all that work I almost wish I would have waited and just found an SC300 master cylinder, but I got tired of looking and didn't want to pay the price of ones I did find.
blk97,
its running fantastic and I am loving the clutch even though it is killing my calf. After about a month I'm gonna look like some kind of freak cuz my left leg is going to be so much bigger than my right. rofl.
lemmiewink,
Yes I am reusing the SC300 d/s as of now, and it is a little too short, I am having a custom one made soon. But what I did was add a couple extra washer in the back and scooted it forward a little to take up the slack. When I tried to use the MKIII front halfshaft it made it too long. Keep in mine this is a 400 so that might be why it wasn't working perfectly. I was not the one that swapped the motor in and I'm not sure if they swapped the whole subframe or just did the mounts.
As for the shop, check this out. I am in colllege (OU) and can no way afford to rent, own, or purchase a shop right now. So one day this guy stops by and sees my bro's 2nd gen Rx7 and stopped and talked rotary with him for a bit. Come to find out hes this old extremely loaded ex biologist with only time and money left over from his retirement. So he offers to let just let me and my brother use his shop free and clear, and throws us the keys. Under the condition that I give him a ride when I was done. I had to pick my jaw up off the ground.
Jon
The old guy loves MG's, heres a few pics we took:
![](http://i25.tinypic.com/295zfrd.jpg)
![](http://i26.tinypic.com/27zlphv.jpg)
blk97,
lemmiewink,
Jon
![](http://i32.tinypic.com/2nw2635.jpg)
Nice mg's .Ive worked with a couple mg's and triumph's .It was a pain to get in these car and im not even 6 feet .They are really fun cars though i wonder how it will react to a 1j
Guys,
I've added/changed some things through out the thread. I added some part numbers for everthing you need to assymble the hub and T/O bearing (minus one oem part number). Also added a couple pics, etc.
After doing some research on the speedo sensor, I have also found out that the sensors out of a supra were all cable driven however, all of the sensors out of a Lexus 5 spd used that 3 pin connector and is electronic.
Good to have the part number though incase anyone needs it, thanks 32SC.
Jon
