How I swapped an R154 into my SC400
#48
#52
#53
i hope someone knows a definate answer to this. i called a lexus dealer and they told me that both the auto and 5 speed cross members from 1992-1997 have the same part number and there is only one available so i can assume that they are identical. unless someone has some proof lol lol
#54
i had a question? iam planning to swap a mkIII supra w58 (non turbo trans) to my 93 sc300. so a mkIII supra manual driveshaft wont work? what driveshaft would i have to get, a 1jz one? I am not 100% sure but do i need to swap the belthousing to a 1jz too, also would i need a 1jz flywheel and clutch?
i thought my 240sx auto manual swap was hard. time to search for more manual swap threads
#56
great info man just read though 3 pages blah cant make it to the last. clocking of the pedals for mkiii pedals just saved me the trouble you went though.mkiii parts are so much easier to find than mkiv supras and scs
#57
Some great info provided by ridox
1JZGTE w/ R154 = 7MGTE Clutch + 1JZGTE Flywheel + 1JZGTE Bell housing
2JZGTE w/ R154 = 7MGTE Clutch + 1JZGTE Flywheel + (may need 1JZGTE Bell housing)
2JZGTE w/ V160 = 2JZGTE Clutch + 2JZGTE Flywheel
2JZGTE w/ W58 = 2JZGE Clutch + 2JZGE Flywheel
1JZGTE w/ W58 = 2JZGE Clutch + 2JZGE Flywheel
Also if you guys need a 1JZGTE chromoly lightweight flywheel. I picked up one from www.gripforce.com for $198. It weighs 13.5 LBS and is solid one-piece billet chromoly steel. Its a new item so I would call to order.
#58
Holy freaking cow! LMFAO it is absolutely unbelieable how much this thread has been messed with by moderators. First they delete half of my stuff, so i delete the rest of it and moved it to another forum. Now it's magically all back to place! HAHAHA.
