How I swapped an R154 into my SC400
#77
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Propshaft lenghtening came out... WITH balancing and pait.... 200 $ BOOM!!! But in Denmark.. so have NO clue of what the price is stateside...
#78
dang! im movin to denmark!! lol got any pics of the car?
#81
hats off to you, great write up.
but could somebody tell me what id not use if my car isnt turbo? to my knowledge, i just get a not turbo clutch.. right?
#83
love the write up hopefully soon i will be attempting this on my 2000 gs300 2jzge motor and if you care to check it out this is my other project ive been working on the last 2 years
http://www.rangerpowersports.com/for...ld-281735.html
#84
I know this is an old thread but I'm posting here to get some clarification on what rubber transmission mount and crossmember were used for 2jzlex's swap.
In reference to post #10 on page 1: https://www.clublexus.com/forums/3524696-post10.html
2jzlex, in the crossmember comparison picture you said you used an SC300 5-speed crossmember with redrilled mounting holes, correct? But what rubber mount did you use for your R154? I have the same version transmission as you did and the mounting holes do not line up with the SC300 W58 transmission mount, which are offset. The MKIII R154 has parallel mounting holes for the mount.
Were you in some way able to use the MKIII transmission mount with the SC300 5-speed crossmember?
I know Shern ran into this problem with his swap and came up with a solution and companies like Driftmotion sell an aftermarket mount with spacers for the crossmember but I'd like to copy your method.
