pics of wet kit install on sc400
Old 05-17-08, 11:50 AM
rayray76
rayray76's Avatar
Default pics of wet kit install on sc400
Can anyone send me pics of of how they tapped fuel rail and placement of solenoids ,wot switch etc. getting cheap wet kit and been watching vids online of how to install. Im pretty sure i have the concepts down just would like pics of a wet kit installed on a 92-95 sc400 to be on safe side. I searched but no pics on an actuall install. any help appreciated.
thanks.
rahimawe@hotmail.com for pics.. thanks.
Old 05-17-08, 05:03 PM
rayray76
rayray76's Avatar
Default or
IF no one has any pics but could provide a explanation of how to tap the fuel rail and also Im trying to use a RPM window switch but seeing as how there is no "coil" i cant figure that one out either.. if anyone has ever played with this stuff
any help is much appreciated.. thanks.
Old 05-19-08, 07:12 PM
rayray76
rayray76's Avatar
Default zeroing in
can anyone tell me if i can tap with a connector off of one of these hoses to get fuel for fuel solenoid and pressure switch .. Does anyone recognize these hoses i know they carry fuel but at what psi..? does anyone recognize these from a 95 sc400 and can shed some light ..
Thanks.
Old 05-19-08, 07:51 PM
RedPhoenix
RedPhoenix's Avatar
one of those lines is before the FPR and the other should be a return. cant tell you which is which tho.
Old 05-19-08, 10:23 PM
rayray76
rayray76's Avatar
Default What about pressure
Ok one line is the return this has low pressure .. the one that goes to FPR is that a hihg pressure line?? 40+psi?? anyone know.. I dont want to cut into this stuff for nothing and still need to tap somewhere else after words.. currently looking for some kind o fiting to tap off those connectors .. from my investigatin they are m12X1.25 but im unable to find some kind of T or fuel adpater to fit..
colinodon
Performance
08-07-16 10:01 AM
seeya
SC400 / 300 Classifieds
12-29-06 07:57 PM
jgscott
Performance
04-13-06 04:35 PM
chrisman
04-24-05 10:05 PM
Quick Reply: pics of wet kit install on sc400
