Trans Swap
I have a 95 400 and i was wondering if theres a swap kit for an auto to man. I would love to keep the quad cam but it would have to be 5 or 6 speed. Any luck on the match up ?
The swap isnt very straightfoward and there are no kits in the US that help with this conversion. There are a few in the UK and Australia but they might get costly and take a looonnngg time to ship. The best way is to just gather your parts here in the US to save you some time and cash.
You'll need a lot of things including a trans (W58, R154, or the six-speed V160), custom bellhousing or adaptor plate, flywheel modifications (custom button or machined ones), clutch, trans accessories like slave cylinder, clutch pedal, clutch lines...the list goes on for a bit. Check out Blizzy's and ScottURnot's threads on their swaps. They will probably chime in here too.
Here are some helpful links to get you started in the right direction
www.lextreme.com <------Lexus V8 forums, very informative about swaps, mods,etc.
http://ttcperformance.com/shop/index...emart&Itemid=1<--------Custom adpator plate for the 3 trannys mentioned earlier
https://www.clublexus.com/forums/sho...d.php?t=290641 <--------Blizzy's 5-speed swap
https://www.clublexus.com/forums/sho...d.php?t=316384 <------ScottURnot's 6-speed swap
hope this helps
hope this helps
Helps tons, thx alot! I was told at one point not knowing if it were true that you could use custom adap. plate a supra 6 speed would bolt up ... that true ?
MattStarr
Performance & Maintenance
11-06-12 01:45 PM
