Has anyone here ever retrofited an R-12 A/C to R-134a?
I'm ase certified in this, the proper way would be to vacuum down the system. You do want to replace the receiver/drier, it will still be holding the chlorofluorocarbons. r12 and r134a systems use different oil for the compressor as well which can only properly be measure by a evac recycling machine like a robinair. r12 and r134a are not compatible, all the kit includes is shrader to r134a fittings. Thats not all you need, you can however get a product called freeze 12 which is a direct r12 replacement and has no harmful chlorofluorocarbons... You really need to have it done by a recycle machine either way, you need to pull a vacuum to pull the new refrigerant in and it has a measuring device to put the pag oil in line. If the proper amount isn't put in or to much as well can have black death to the system as they cal it in the industry. You'll know when you smell it ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Originally Posted by kyoso23
Ghetto style. Cracked open the system, installed new dryer, new oRings, retrofit nozzles, fill. The cans usually have a gauge on them to read the pressure. Definitely not the right way, but I did everything for ~$45. Worked great each time (except for the global warming)
KC
i have done my dads corrado all i did was replace the reciver dryer and all the o rings. sense r134 runs at higher pressures the propper way is to get a bigger condensor and evaperator but you dont really have to. i have access to a ac machine so it wasnt that big of a deal. just do all the work your self and go to a place and have them charger it and tell them you have converted it. not a big deal. my dads car blows 40 degrees at idle and even colder while driving
You "can" just add it to the existing system. Chances are though you adding cuz you have a pretty good leak. Check and see if you low side is putting out 10 units or less during idle. If so there is going to be air in the system and you need to evacuate. Chances are you need to add oil at this point and you have to do that first before putting any refrigerant in.
I've doon it on two other cars of mine. No problems and it works just as good! Just make sure the system is evacuated of R-12, change the fill valves and you are all set.
I just called a local shop and got a quote of $170 to convert to R-134a. They really didn't go into too much detail as to how they convert EXCEPT to tell me that they did not have a machine to extract the R-12. To ge tthe R-12 out they simply release it to the atmosphere. I was told this is highly illegal (a felony).
Are you guys even adding oil when re gasing the system? The proper way to do it will include replacing drier, o rings and what not ,then you have to vacuume it andd oil and after that then you add freon. Failure to do this will cause the system to get contaminated and parts will start to fail.
let me chim in here, first auto zones kit wont work the low side valve is too large you will only be able to adapt the high side not recommended unles you shoot the freon in small tiny burst and you will need a high pressure guage up to 300 psi or more. the correct kit for the nippondenso compressor is called READY AIRE THEY MAKE 3 KITS ONE WITH OIL ONE WITHOUT ETC. summit has the valves any other kit wont be able to work on the low side,if you vacumm it completely you will mneed the correct oil. if you put it in an empty system you can use the neutralizing oil wich cancels the old oil and allows for the newer oil for the 134, included in the kit, my recommendation is as follows, remove compressor, fir it with new seals kit can be bought at ac store compressor seal kit comes with all o rings and seals, change dryer, be carefull the dryer holes are diffferent on some of the dryers better to take yours out and match it at the store also replace those o rings ,forgot to mention remove freon first from system use vacuum, drain compressor oil, clean compressor so when you put it back will make it easier to see any leaks, once everything is back together again vacuum the system best way is to keep vacuum overnight but most cases this cant be done because of lack of equipment also after vacuum put dye in and fill system with nitrogen dosent harm syste and cakn be released in the air after leak test, when you determine that it is not leaking, hook up low side and fill with 134a while ac is on and car is running, r12 compressor uses a low pressure system 134 uses a high system, so it wont get as nearly as cold but it will be satisfying, different opinions on the feel of coldness, no 2 the same, easier way if your system is tight the r-12 replacement without mods s called FREEZE 12. put it in and go the secret to it all is no leaks and correct high and low pressures i think 250-300 or more high side 250 to be safe low side 40-45 psi not sure check with lexus or an ac spec book, this is just my expierience with the change over still working on it cant find a leak suspect its in the compressor waiting for another one will update when done
ok so heres the thing the fitting kits work you pretty much need to evacuate the system and place the new fittings on high side and low side then recharge it and your good to go doesn't work as great but it works enough.
Listers
GX - 1st Gen (2003-2009)
10-28-17 11:10 AM
