Chaser R154 to 92 SC300 w/GTE Fitment Issue
Providing the engine will have clerance this will be great if you can use the mk3 r154 without any shifter mods. Now what im wondering is if this will have any benifits in handling since the motor is placed further back.
sc250tt, i just verified by looking at a few other pictures of engines and the stock sc bracket has the mount forward of center which pushes the engine back as far as possible already. so unless someone can confirm that the 96- tt bracket/mount is different from the sc bracket/mount from a horizontal axis perspective (which i highly doubt), cherplex is running into a different issue.
can anyone tell that i'd rather be researching or working on my car than actually doing work??? =)
anything that is not further forward than the sc bracket will not push the engine further back...damn double negatives...ie, if it's in line w/ the center, then it actually moves the engine forward.
Are the soarer brackets the same as the sc? If not then the supra brackets that sherwin is using is putting the engine back 2 cm .This is the issue he is having and the only thing that ill cause this is the brackets. So these brackets on any jz engine will put it back 2 inches.Can anyone confirm that the sc brackets is the same as the soarer?
its gotta be something with the chaser r154. when i have talked to you i was under the impression that it was a soarer r154. I dont know the difference if any but you have all the same parts as me and everything fits like a glove in mine
here's a thought cherplex. i think there are different tranny tunnels depending what kind of tranny. take this as an example: soarer has 2 different r154's...one has a swan neck and the other has straight type shifter. if swan neck, the hole is further forward, if straight, hole is more towards the rear.
i was looking at my shifter area the other day and the hole was very specific to the tranny in the car...ie, the area where the shifter connects to the tranny is in one specific location and swan neck shifter is used to place it in the correct location on the shifter console. my car would not be able to fit the straight soarer tranny as the hole would not line up like in ur pictures. i believe urs is the same, it had the early w58 transmission, using the swan neck shifter.
I bet Blair received an early version Soarer R154 transmission from JHot when he did his swap (would be verified if Blair knows or remembers if his shift rod was swan-necked).
Sherwin, clearly you have a different iteration of the transmission, and the 1-2" of extra depth that you are experiencing is compensation for the straight angled shifter.
Nice thinking crazy. It looks like you have hit the nail on the head.
shows u guys how much research and thinking i've been doing on this r154 swap. just missing the 1jz flywheel and work can begin...once i schedule some time w/ my friend to use his 4 post. then turn up boost!
Thats crazy. I'm assuming all USDM sc300's with the W58 have the same mounting location, but the 92-95 soarer/96+ soarer's have different locations.
Even if you had your trans tunnel cut open, would the shifter mount correctly inside the cabin with the shift boot?
Cherplex. I'll trade you soarer transmissions =P. I have the early model swan shifter.
