Going the 1JZ route
Old 06-23-08, 10:04 AM
  #31
OneJay
OneJay's Avatar
I have a new timing belt, water pump, spark plugs, and drive belt. I couldn't break the crankshaft nut loose with it out of the car, so before I put the radiator in I'm going to change the timing belt and water pump. Most people just put a breaker bar over the wrench, wedge it against the ground, and crank the engine for like half a second to break it loose. I'll probably have the car running by tomorrow, so I'll change them either tomorrow or wednesday.
Old 06-23-08, 02:33 PM
  #32
OneJay
OneJay's Avatar
Progress from yesterday. We got the engine in, and got a lot of things hooked up, and all the intercooler piping figured out.
Old 06-24-08, 01:44 AM
  #33
soarer13oy
soarer13oy's Avatar
so how does all the vaccum run?
Old 06-24-08, 10:15 AM
  #34
CCC-TT
CCC-TT's Avatar
what year SC is this?
Old 06-24-08, 06:23 PM
  #35
t70 supra
t70 supra's Avatar
is that a supra 1jz
Old 06-24-08, 07:18 PM
  #36
CCC-TT
CCC-TT's Avatar
Originally Posted by t70 supra
is that a supra 1jz
supra 1jz's will not drop directly into an sc like this one did... its from a soarer
Old 06-24-08, 07:39 PM
  #37
OneJay
OneJay's Avatar
Its a 95. And the 1jz is from a Soarer. It should be a pretty easy swap for most, but its proving pretty difficult for me as this is my first one. lol
Old 06-24-08, 09:51 PM
  #38
CCC-TT
CCC-TT's Avatar
dont worry, you'll get it figured out. once youve got it in, dont expect it to run perfectly though, just pray you dont have any of that stupid 3k sputtering crap... its a PITA!!! but in the end you'll get it running right and it will be that much sweeter. Good luck bro.
Old 06-24-08, 10:21 PM
  #39
OneJay
OneJay's Avatar
Thanks bud. Ya, I hope it runs right the first time. I would hate to go back and redo all that stuff. I read your thread about the 3k BS and that would be a real pain in my *******. How long did it take you to sort out?
Old 06-25-08, 08:47 AM
  #40
pinoyFMtC
pinoyFMtC's Avatar
Finally got the pics up huh? I hope we get this swap done soon lol...
Old 06-25-08, 10:05 AM
  #41
OneJay
OneJay's Avatar
Haha. Hey dude. Ya. Hopefully.
Old 06-25-08, 10:33 AM
  #42
aka paco
aka paco's Avatar
95's and up are normally more of a pain, i'm pretty sure all the 95's have that 3k rpm problem, mine did as well..
Old 06-25-08, 11:08 AM
  #43
OneJay
OneJay's Avatar
Did you ever resolve that issue?
If you did, what did you do?
Old 06-25-08, 02:06 PM
  #44
OneJay
OneJay's Avatar
Update:
Started on the first crank and effin purrs. We cheated though and bypassed the starter. We still need to figure out how to do the neutral bypass. We've tried sticking a fuse in the grey plug that was from the auto, but it didn't work. If anyone knows how to do this neutral bypass, let me know. Thanks.
Old 06-25-08, 02:13 PM
  #45
OneJay
OneJay's Avatar
Oh, and by the way, if you take out the starter bypass, and plug in the necessary plug, it cranks when you connect the battery. any info about this would be good too. Thanks.
Quick Reply: Going the 1JZ route
