Sc300 2jz-gtte Vvt-i
I'm a newbie on lexus. I've been a Honda lover so anyways I have a 2000 lexus SC300.
I just ordered a JDM 2jz-gtte 6spd and I was woundering what else do I need for the swap?
Like every forum, we have tools in here too!
Anyway, are you doing the swap or a shop?
I hope you have the front clip because you need most MKIV parts for the swap. You also need the custom drive shaft because transmission sits further back than SC transmission.
By the way, try to search first and then ask a specific question instead opening yourself to unfriendly commnents.
Good luck!
Definately search! You should have done lots of searching before you spent your money. This will be a relatively expensive venture, .... especially if your paying someone to do it.
Btw, ... theres no such thing as a 2jz-gtte. There IS a 2jz-gte.
240killer
Performance & Maintenance
19
10-10-05 10:52 PM
