na-t ?
Old 06-01-08, 07:11 PM
crza81
crza81's Avatar
Default na-t ?
whats the best na-t turbo kit? looking to get 450-500 on a 97 sc300 5spd.
Old 06-01-08, 07:18 PM
93sc3005sp
93sc3005sp's Avatar
check out clubnat.com
Old 06-01-08, 10:10 PM
OneJay
OneJay's Avatar
^^^ +1. (ten characters)
Old 06-02-08, 12:25 AM
frdykrugar
frdykrugar's Avatar
XSPower FTMFW yay
Old 06-02-08, 09:35 AM
FormosaSC
FormosaSC's Avatar
ive heard xspower is pretty good but daveH is the good stuff.
Old 08-03-08, 11:58 AM
FL1PP3D
FL1PP3D's Avatar
I'm still stuck between choosing both kits. Anyone know which is better? I have the same power goals as the topic creator.
Old 08-03-08, 12:04 PM
plex
1UZFE/2JZGTE
plex's Avatar
What's your budget?
Old 08-03-08, 12:07 PM
FL1PP3D
FL1PP3D's Avatar
I guess around 2k. But I'll be willing to pay a bit more if it's worth it.
Old 08-03-08, 01:00 PM
plex
1UZFE/2JZGTE
plex's Avatar
I was referring to the OP but 2K is doable if you're doing everything yourself.
Old 08-03-08, 02:37 PM
TLDriver
TLDriver's Avatar
https://www.clublexus.com/forums/sho...d.php?t=371118
i know it's more then 2k but... gl
Old 08-03-08, 03:58 PM
over40driv
over40driv's Avatar
Since your on the subject, does na-t only mean turboing the factory SC300 3.0?
Old 08-04-08, 12:34 AM
FormosaSC
FormosaSC's Avatar
na-t means going forced induction on a naturally aspirated engine. It can be used on any car. a corolla can go na-t
Old 08-04-08, 12:44 AM
madmax98
madmax98's Avatar
It pays <a lot> to put the kit together yourself. Also, "you get what you pay for" doesn't always apply... The Sp63 seems like a good option for a street car, maybe a similar DBB
Old 08-09-08, 08:09 PM
davidv433
davidv433's Avatar
i just picked up an xspower t3/super t70 for 80$ is that a good turbo, is anyone in here using it ?
Old 08-10-08, 06:30 PM
madmax98
madmax98's Avatar
T70!!! I thought you wanted a streetable setup. T70 will not spool quickly enough for a sreet car unless you're willing to use nitrous. From my research, 67 or even a 63 mm turbo will be more than enough for you HP goals and will be fun on the street. Some guy broke in the 620 WHP with SP63 on a conservative tune. I really recommend checking the dyno section on SF, it will give you a great idea about the spol characteristics.
Quick Reply: na-t ?
