2JZ swap? Searched but cant find the answer.
I have a 2jz out of an aristo. If I convert it to usdm i.e. ecu, wiring harness, injectors, MAF.... Would it then be a strait swap into my 95 5spd (no need to modify wiring)?
Thanks
Thanks
im not sure about the body plugs. im pretty positive that with the jap ECU and usdm full wireharness it would be considered a plug and play swap. you'll need a new flywheel for the stock w58 tranny though
