92 sc400 Just purchased with problems
Hello guys,
I just joined the lexus family. I am coming to you from Honda![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
However, I am having some issues. I have been searching the forums to see what the cause of my problems could be. Here are my issues. The car is laggy. When I stump the throttle it revs up, but pulls slowly. When I first got the car it only had one coil wire plugged up, so naturally I purchased some wires and put the coil wire on. I haven't replaced all the plugs yet, because the guy I got it from said that he had just put them on and they look fairly new.
After plugging the coil up. It wasn't too much better. So, I figured that the cats where clogged. So, I had new cats installed today. While I was at it, I had the middle resonator taken out and created a true dual exhaust. After all this is done, the car sounds different, but still laggy. I plan on changing all the plugs tomorrow along with the wires. Although the plugs are fairly new, due to the coil not being plugged up, they make be fouled out. I also, have new distributor caps and rotors coming. I am new to the lexus/toyota world, but I now the car is suppose to pull a whole lot harder than it is now, I think. correct me if I am wrong.
Do you guys have any other suggestions as to what may be wrong? The car has 185K on it. Thanks in advance.
Well according to the jolt I received from the coils while the car was running, leads me to think that it's not the coils. When I pull the coil on the passenger side the car won't start, but it started when i pull the plug on the coil on the driver side.
Since both coils shocked me, I assummed it was the distributor cap and rotor on the driver side not good. So, I pulled a plug wire and stuck a screw driver in it to try and see it arc...nothing. So, now I think it is the dizzy cap and rotor, so I ordered both dizzy caps and rotors. Hopefully this cures my problem.
Might check your throttle position sensor, and does it down shift when you stomp on it? Might tighten up and adjust your tranny kick down cable...
Don't believe the dual exhaust on the SC400 is better without the cross connect. I think it works better with it to balance each bank, but not that sure.
Also, while you are doing all this stuff, make sure you have the Lexus recommended Denso or NGK plugs (and not the other replacements that some auto parts stores will sell you) along with the original Lexus parts for the spark plug wire and harness clips to make sure the wires are crossed properly around the engine.
Good Luck,
Tim
Good Luck,
Tim
Good Luck,
Tim
Good Luck,
Tim
So, I had the cats replaced and finally figured out why it was running on only 4 cylinders. The rotor in one of the distributors had broke all up. I replaced both caps and rotors and while I was at it, I installed the KN filter kit.
I thought things were fixed, but when i start the car it idles at 2500-3000rpms. I thought it was the MAF, so I got one from the junkyard, but it threw the same codes. Which are:
24-Intake air temp sensor
25-Air-fuel ratio lean malfunction
31-Air flow meter signal
My next steps are to purchase another MAF and replace all the O2 Sensors which I have already ordered.
What do you guys think is going on?
Okay. I'm thinking it may be one of the problems, but I will get the o2 sensors tomorrow and go from there, because as we know one problem can cause multiple codes.
