Degreased engine and it stopped running
I bought the Gunk engine cleaner and started spraying it on my engine bay with most of the electrical components covered up, but somehow water slipped through. Immediately after spaying it off with the hose, i started it up and it ran fine. Later that day it started sputtering and missing on and off. Then my check engine light lit up and i kept driving it because i thought if the engine got too hot then the water might evaporate. I went on the HW today and wanted to get the engine real hot but it started to miss real bad and i pulled over after some time but when i did i noticed there was blue smoke coming from under engine. I had it towed back to Toyota to get it inspectioned. I will have them diagnose the problem and CEL's code. Could it be the spark plugs, wires, distributer. Blue smoke means oil burning, is that true and how did that happen. Any help is appreciated.
jeancarlos (07-16-21)
Usually blue-ish smoke means water(steam) more than "smoke" which comes out black. When I cleaned my first SC's motor mine sputtered a little because water got into the S.P's but it was fine after about 30-60 mins.
Thanks for the fast reply. I hope its nothing serious, because my DaveH turbo kit is on its way and i will be dropping my car off at the shop next week. With my NA-T install i will be getting cold temp plugs so i hope i don't have to get regular plugs now and then have to get cold temp later.
You take your chances when you wash your engine.
You have no idea what unholy hell have you unleased. You've got company, what ever you managed to do to your engine while washing has happened before:
a warning to all sc300 owners!!!
Washed my engin then....
My buddy sprayed off his SC's motor and now its misfiring. Cause?
power washed engine and now missing on 4 cyl's
SC300 engine idles strange
help! engine shuttering
Help!!! My SC might be damaged!!!
for the second time in a row, I washed my engine
Water in Intake Manifold Spark Plugs
Bad Engine Skip
Bad Engine Skip
Keeper of the light
Bad Engine Skip
Bad Engine Skip
i just drove my sc2jz-ge into a lake of water and simple green and it didnt run for two days.....so i bought a 1jz-gte 5speed...............................................J/P
i drove my sc400 thru an overflowing creek... water everywhere! needless to say, it doesn't run anymore. I pulled the airfilter out of the box and it was just dripping. i pulled the spark plugs and cranked the engine and you shoulda seen the spray of water! looked like old faithful! water in engine! anyway, i'm changing the oil this morning and putting everything back together. we'll see what happens... oh, btw, engine is still dirty!
