Any ideas about this 7mgte clutch pedal?
Okay.. so far so good.. What about the mkiii clutch master cylinder, would it fit onto the sc300? I'm talking about the 2 studs that go through the firewall to the interior. Are they lined up perfectly after I drill through the pre-drilled holes of the firewall?
I take you through it step by step in the link that he was kind enough to provide.... you're definately going to want to read through it if you are using the MKIII pedal assymbley and master cylinder. It does NOT bolt right up. good luck.
jon
jon
So I guess you're wrong about the mkiii clutch pedal 5spd_jzz30.
The MKIII pedal/master cylinder WILL work. But it doesn't bolt right up is what I meant. You cannot use the stock cutout pattern, studs, and you have to find a way to extend the connecting rod between the master cylinder and pedal. Not to mention getting those nuts on the backside of those studs to hold them together is major PITA. O yeah and some cutting.. To save you time and trouble, and if you're not gonna start the swap unitl later on, take the time to find an SC3 pedal assymbley and master cylinder. Mine works perfectly but if I had to do it again I would find the SC parts.
The worse parts about this forum is having people assume things will work without even having experienced it. God... Unbelievable. I'll find a way though; I'm not going to let 5spd_jzz30 screw me over like this. What da hell was he talking about?
Dude stop being cheap and get the right pedels for the car. Supra pedels was meant for a supra. You can get a clutch pedal from any lexus dealer on this planet.
Dont blame 5 spd, there are alot of members that give out rando information thinking its correct just cuz they read it somewhere, I think we have all done our fair share of that. IIRC 5spd is ALL ABOUT the "cheaper" ways anyhow.. If you are deadset on making it work, just be ready for some cusswords.
Good luck
Jon
Good luck
Jon
Good luck
Jon
Good luck
Jon
Hey DUDE..., I ain't no cheap as alright? SC300 pedals are pretty rare alright DUDE? Quit trying to come up rude behind the monitor. And I ain't gonna pay no stealership that kind of money for brand new parts alright DUDE? I'm pretty **** right now, and the last thing I need is someone to accuse of being cheap.. So lay off and and don't even talk to me. You wana talk, email me jjsc3@yahoo.com.
