1JZ 2JZ oil pan
Old 06-27-08, 09:00 PM
phil2235nt
phil2235nt's Avatar
Default 1JZ 2JZ oil pan
Im plannin on doing a 1J swap soon and I wanted to know if the 2J USDM oil pan would work
Old 06-27-08, 09:46 PM
rwdanthony
rwdanthony's Avatar
why not just the oil pan that comes with the 1jz? or are you planning to get parts individually/seperate?
Old 06-27-08, 10:04 PM
5sp_jzz30
5sp_jzz30's Avatar
he might have a 1jz out of a cresta or a chaser. on those cars i believe its a front sump. you can use a 2jz upper and lower pans on a 1jz block. you need to make accommodations for the turbo oil return line.
Old 06-30-08, 07:50 PM
phil2235nt
phil2235nt's Avatar
what if im doing a swap ot of a 1j MKIII supra or if im doing a 2j Swap out of an aristo clip
estomax
09-11-13 05:12 AM
2jzsx
SC400 / 300 Classifieds
05-16-12 03:46 PM
veltall
11-14-09 12:39 PM
dinhnerz
09-05-08 02:27 PM
LexusLimit
13
08-01-05 06:43 PM
Quick Reply: 1JZ 2JZ oil pan
