1JZGTE VVTI Swap info needed... Searched everything
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
Im in some desperate need of finding some ecu pin-outs for a 1jz vvti chaser. I have searched and only came up with some dead links. Swapping a 1jzgte vvti engine into a 99 vvti sc300. Only two of the ecu plugs fit i have no problem wiring if i could find the diagrams. Also will i have to change over any of the body plugs? Hopefully someone has done the swap and could post some info.
Posted a few pics and a pdf of the only pinout i could find. Not sure if it even close though.
Thanks
![](http://i33.photobucket.com/albums/d57/gwensbluetears/Jims%20stuff/100_21522.jpg)
![](http://i33.photobucket.com/albums/d57/gwensbluetears/Jims%20stuff/100_21512.jpg)
Thanks
![](http://i33.photobucket.com/albums/d57/gwensbluetears/Jims%20stuff/100_21491.jpg)
Former Sponsor - Cancelled
That's a JZX100 and yeah it is different. I can help you with that wiring conversion. Shoot me an email at drtweak@phoenixtuning.com
-Doc
-Doc
Pm me your email address, some of the files are big, thats why i assuming i can't attach them here. If i can figure it out or get smaller ones to share i will post them in the thread or i will email them to you. What motor are you trying to put in, a vvti or non-vvti from a chaser?
Here are the wiring diagrams. More to come. Please add any information that may help.
http://www.fileden.com/files/2008/7/...x100chaser.pdf
http://www.fileden.com/files/2008/7/...ing%20Comp.xls
http://www.fileden.com/files/2008/7/...359/Soarer.pdf
http://www.fileden.com/files/2008/7/...59/chaser2.pdf
Anyone else have any other info to add please put it up for others as well as me
, to help with all future swaps, most of the info i found online was from toyomods.com, they do this swap a bit more over there. If you are having trouble posting it let me know and i can help put it up. Hopefully we will start seeing more of these swaps being completed.
I am looking for the factory body plug harnesses from a 99 or other year lexus if anyone has them.
Anyone have the Soarer Bible? I have only heard of this, not received a full copy yet online.
here are some other places i found info on this swap, if anyone else wants to add anything to this thread that might be helpful? HINT HINT
http://www.jzgte.com/tech/1jzgte/Soarer.pdf
http://www.3sgte.com/1JZGTE.htm
http://www.1jz.com/tech/docs/engine_manual/
http://www.modifiedlife.com/
http://www.toyomods.com
Hi, sorry if this is an old thread, I am trying hard to find an automatic 1jzgte w/ vvti ecu. I can almost read those number's on your first picture there. could you tell me what the part number is on that jzx100 vvti 1jzgte is please. Also if anyone know's the factory part number for the injectors I could use some help. I have 4 of the six injectors and am kind of stuck. Thank you!
