PLEASE help identify this sound.
OK, so I just took off my air intake, throttle body, and plenum. Put in new spark plugs, plug wires, new gaskets, replaced the PCV, cleaned TB and Plenum, re-attached all the hoses and put everything back together. Also changed the coolant and oil.
The car will start; however, it has a loud clicking noise. Similar to a baseball card in bike spokes, but pretty darn loud. The car also feels a bit shaky from the inside, but when looking at the engine it doesn't seem to me moving itself.
We didn't change any timing, but we did put it in TDC using the crank pulley since we mistakenly though that was needed to but the distributor cap back on.
The plugs that I bought were NGK Iridium, made for the SC300 ... stated to be actory gapped correctly, but I didnt check this out. Could this be it?
Any ideas at all as to what could be causing this?
Sorry OLT
, but I have to be at work in the AM in this car...
Sorry OLT
you sure all your wires are pushed on nice and tight on the distributor? sounds like a arching sound from a spark arhching somehwere on the engine. either you broke a wire or you didnt plug one in all the way somewhere. from the sounds of the car not running right and ECT, get a watter bottle and put on mist mode and spart the spark plug wires in a dark area and look for a light show
Alright, it seems like the spark plug wires were not on tight enough on the disty cap. That has been resolved. Now, another question on a whole other subject - I changed my sway bar bushings and when I went to torque them, one of the bolts broke at the head. Not sure why it did that - but now I have a half a bolt stuck in there and I am not sure it can be driven that way. Any suggestions on what I should do here?
wooziewest
Performance & Maintenance
34
10-27-09 10:40 PM
banking
SC- 1st Gen (1992-2000)
21
12-06-01 10:57 AM
