Help!!!
Help!!!
Okay so my sc has a problem, the drivers side window wont go up or down! could this be the switch or the regulator????
the driver side switch only unlocks and locks both doors so im thinking there are two components to the swith, then again i could be wrong!!!
any help would be greatly appreciated!!!
Check to see if the wires to the window switch are getting power. Over time, the wires can get frayed with the door opening and closing so much.
See if you can find someone locally who will let you pop their switch out and put yours in... Takes all of 10 seconds.
Jonny
Jonny
super58177
08-25-08 04:01 PM
