neutral safety switch
Ive done 2 swaps and am about to get started on a 3rd one this week. After months of research I just couldnt figure out how to bypass the neutral safety switch so I can start the car with the turn of the key. What I did was:
- I grabbed the biggest harness plug left over from the auto tranny.
- Using a power tester you poke every pin (while having the key in the "ON" position) until two of them light up.
- You cut and splice those two wires.
- Extend them into the center console.
- Hook them up to a two pin switch (push start button) which will enable you to start your car when the key is in the "ON" position.
Reverse Lights
Alright so wiring up the reverse lights is fairly easy. I followed the instructions in one of my favorite links:
http://mkiv.com/techarticles/auto_to_6spd_swap/install_6spd/index.html
Really helpful website. Your little "R" indicator in the cluster will light up every time you put it into reverse.
I hope you find this info useful. Good luck.
Reverse Lights
