W58 weak points
Sorry I was just asking lexusdream since he lives in same state as me. I have had a couple friends get killed by others driving erratically on highways. Just concern and I apologize for criticizing anyone's driving techniques and such. Just want to be sure no one gets hurt, either driving or on the same road.
Just be careful guys! I am not saying I am the angel driver but just please be careful!
As for 540whp on a w58 that is impressive! I also heard that I will prolong the life of my w58 by putting in my supra auto tt trd LSD diff in also? Not sure the truth of it all but hey anything that helps and also makes it not do a 1 wheel peel is good for me.
No offense taken. If you don't launch the car or bang gears, it will be fine. High rpm shifts are probably a bit of a weakpoint due to the synchros, but as long as it's done on a limited basis, it'll be ok. You just drive a bit smarter, and more aware when you're pushing big power through it. Mine didn't even break, so I have a working W58 that I pulled out. I just knew it was a ticking time bomb, and felt it was best to go Getrag.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
I'm Getrag equipped now, so I could care less if it needs a rebuild now! I just wasn't able to have any fun with the car because I was always too worried about breaking the tranny, so I upgraded.
so a few of you guys have been fairly hard on your trans with no issues?
I just sold my 1jz auto SC, and bought a 5spd SC it's stock right now but i've been worrying about shifting hard like my trans is made of glass or something lol...
Well I do shift hard, but only about 10%. I'm pretty soft on the transmission otherwise but the other 154,000+ miles where i wasn't behind the wheel im not sure about. If you grandma the tranny while on the streets and only slam gears when you're tearing it up at the track you should get some more life out of your transmission.
Hi guys, I know how you feel about w58, I did a trany swap on my 91 supra turbo and my 3 gear syncros got very very weak as well, I am in the market for a sc and I want to also do a trany swap on it as well, but this time I am going to try r154, its much beefier trany and will hold more hp.
My question is since w58 will mate to 2jzge straight swap, will r154 and 2jzge be a straight forward swap as my w58 with 7mgte? The reason my trany was getting weak it had a 180k on it and it was time.
Thanks
Garen
Thanks
Garen
well hopefully this doesn't drive up the cost of the "weak w series" trannies but i just found out that peak performance makes a dogbox gear set for the w series........ no word on price yet but if its not crazy then this is an awesome alternative to the v160-161 and the getting pricer r154.... bottom of the page
http://www.peak-performance.net/content/view/220/88/
