Any Sc300's with SAFCII? urgent question
Old 07-04-08, 10:37 PM
madmax98
madmax98's Avatar
Default Any 98-00 Sc300's with SAFCII? urgent question
i just installed the safcII on the sc300 98. I followed T10-a everything seems to work till i try to start the engine. I can't start the car and CEL comes on. when i disconnect the MAF wires from the SAFCII and connect them back together, the car goes back to normal. I first used the white and yellow wires for the maf, then i switched to the pink and orange only to get the same outcome. I switched the setting from Karman to Hotwire, still no luck. So, how do you guys connect your maf wires????
Old 07-05-08, 07:11 AM
madmax98
madmax98's Avatar
And what do you set sensor type to???
NSeagle78
Maintenance
09-12-09 09:05 PM
madmax98
07-06-08 02:20 PM
sliva001
01-20-07 07:45 PM
Mpooyan83
06-13-06 03:45 PM
Dx3
04-28-06 03:54 PM
Quick Reply: Any Sc300's with SAFCII? urgent question
