What's going on here : Injectors
Are you using a 7M resistor with those 550cc inj? I think I have a set of 440cc inj. from a JDM 2J, direct swap in with no resistor needed. Might help you troubleshoot the issue.
Josh
Josh
When you say closed loop do you mean "Low" on SAFC? If so, there are adjustments made in that category. I've tried to mess with them but it runs really rough, is there a way I can earase that and only that section on the SAFC so that it runs straight off the ecu until full throttle?
I feel for you I am edxperiencing someth9ing very similar but it goes lean for me. I may have a bad O2 sensor after one of my cats though, well if I had cats it would be the sensor after the cat. I'm going to throw the scantool on it next week to see exacxtly what is going on.
I made some changes in my idle a/f's and it hasn't acted up since. Before it would idle rich, 12-13, and now it's at 15.5. We'll see what happens after a few more days.
