No A/C after AEM EMS install
Once you load the 1101 cal file into the 1100 box it becomes an 1101 setup. As far as I know the boxes are the same and its cheaper to buy a 1100 box and much easier to find.
I have been using the 1100 box for over a year with the 1101 cal file, with all the extras and gotten everything to work including electric fans, evap and even the ACIS system (the little valve in the intake plenum). Wiring is the exact same, you need to install a map sensor and IAT no matter which box you use and they go to the same pins on both boxes.
To Confirm: This does work
This is the correct information... however as he stated no resistor needed and actually if you already have the resistor wired in for and Aristo ECU you must delete it... simply cut the blue wires from it and reconnect the blue wire together...
I HAVE AC AGAIN!!!!! been dying with these record highs here in TN
