No A/C after AEM EMS install
Just like the title says: No A/C after AEM EMS install. Any idea why this happened? I know at the shop they couldn't get my car to stop stalling after coming out of boost with the idle control valve (ICV) connected so it was retuned without the ICV plugged in. No more stalling, but no more A/C either. I think it has to do with that but I'm not sure. Anyone know for sure? If so, what are my options to fix it?
dont quote me on this because i havent use an EMS in years. but i believe there is an option to turn off or on the a/c also an sub option to have it cut on or off at certain rpms or WOT. you need to ask your tuner this to verify.
which aem are u using? should be 1101 box but u can make the 1100 work as well. anyway, the a/c fix requires u to solder a resistor bridged between pins 33b and 34b (off the top of my head so search).
Thanks everyone. I will check with the shop about the A/C options on the EMS and pass on the info about soldering a resistor bridge after doing a little more searching. And I have the 1101. Thanks for the help!
So just to clarify, what are the differences between the 1101 and the 1100?? Other than what seems to be just different Cal file settings which will need to be tweaked anyways.
Is there any negatives to running the 1100 box? Any luxuries lost like tach signal?? etc etc.
I understand that a map sensor / iat sensor will need to wired in but that's for both.
Problem is, 1100 V1 box's can be found farely easily, 1101's are alil harder to come by.
I may just pick up a V2 unit and call it a day lol . This video made me feel better with going to EMS.
http://www.youtube.com/watch?v=yiIV9Sc6FUA
The 1101 is not PNP to the SC because you still have to wire the Ait and Map sensor, so same goes to the 1100.
Use can use either one just load the ge Cal file if your na-t and gte Cal file if your gte.
I think most people can deal with wiring in 2 sensors considering it completely gets rid of stalling related blow off issues and restrictive intakes from the maf. Plus the purchase of a 30 dollar MAC valve and you have a fully adjustable electronic boost controller.
