Boost controller install - how did you you get???
Old 07-11-08 | 07:43 AM
thegadget's Avatar
thegadget
Default Boost controller install - how did you you get???
Hey guys, How did you get to the rear boost vaccum lines? There is no way I can get to them. ( I am using stock turbos from a jdm 1jz). Is there an alternate way to connect the boost controller to the BOV? Thanks!
Attached Thumbnails Boost controller install - how did you you get???-100_1623.jpg
Old 07-11-08 | 07:45 AM
thegadget's Avatar
thegadget
Default Or
Am I stuck doing it this way? Again how to get to the rear???
Attached Thumbnails Boost controller install - how did you you get???-boost_controller_install.jpg
Old 07-11-08 | 08:10 AM
RichSC's Avatar
RichSC
You're more on the right track with the diagram in your second post. The boost controller does not get connected to lines for the BOV. I know on my Supra, the line between the inlet on the turbo housing and wastegate actuator is the one that's tapped. I'm not exactly sure how it works with twins.
Old 07-11-08 | 08:18 AM
thegadget's Avatar
thegadget
Default Thanks for the quick reply.
Thats what I thought... rats
Old 06-14-09 | 06:58 PM
BigManne's Avatar
BigManne
bump for some info. how the hell do you get to the rear turbo waste gate line? my hands are way too fat to get back there.
Old 06-14-09 | 11:43 PM
SH_JZZ30's Avatar
SH_JZZ30
I recently did this on my 1jzgte exactly how the diagram is. You have to remove the inlet on the rear turbo. It's 2 12mm or 10mm bolts. Use a ratcheting wrench if you have one. It was easier. You will have to remove the water line, bov vacuum line, and crankcase ventilation hose.
It wasn't hard removing. But putting back the inlet was hard because the gasket was kept falling off for me. It would be easier for you because you are LHD so you have more room over there.
You just have to look at what needs to move to access that area. I also blocked off the crankcase vent on both inlets and installed a catch can for both lines with a breather filter to prevent oil going into the turbos.
Old 06-15-09 | 03:07 AM
BigManne's Avatar
BigManne
any way it can be done without removing the coolant line?
Old 06-15-09 | 10:06 AM
SH_JZZ30's Avatar
SH_JZZ30
The coolant line is connected to a bracket that's in the way. It's only a clamp that needs to be removed at the top and it pulls out. Once your remove the inlet, you can remove the bracket. I even removed the stock bov so it's not in the way.
Old 06-15-09 | 03:05 PM
BigManne's Avatar
BigManne
ok cool i think i can pull it off now. thanks for the info.
Old 06-15-09 | 06:53 PM
BigManne's Avatar
BigManne
well i think my hands are too big or my tools suck because i cant get to any of those bolts.
Old 06-16-09 | 08:43 PM
ucfa4's Avatar
ucfa4
You could do it without removing anything just get someone w small hands. I dont think you will find anyone to fess up to that though. lol
Old 06-16-09 | 11:36 PM
BigManne's Avatar
BigManne
true. wonder if i can get to it from the bottom of the car. maybe on a lift.
Old 06-17-09 | 10:30 AM
ICONYQ's Avatar
ICONYQ
LOL this is getting comical. Hire a 10 year old that is home for the summer
Old 06-17-09 | 04:54 PM
BigManne's Avatar
BigManne
ahh my step brother to the rescue.
Felts
06-28-20 09:13 PM
INTIMAZY
01-08-12 04:37 PM
Turbo?
07-27-08 10:29 AM
ucfa4
11-15-07 05:42 PM
IS300_POLO
IS - 1st Gen (2001-2005)
15
08-31-02 04:47 AM
