new to lexus...need help on setting timing.
Old 07-12-08, 01:35 PM
2jz02
2jz02's Avatar
Default new to lexus...need help on setting timing.
I have my distributor off and now cannot get my ride to run right. Could someone help me with the timing? setting? degree? and rotor point to?...Thanks
Old 07-12-08, 01:58 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Old 07-12-08, 05:09 PM
2jz02
2jz02's Avatar
car is running...but for a stand still 900 to 4000 rpm the car feel very slow...anyone know what going on here? Please help me out...i need help badly....Thanks
Old 07-13-08, 04:04 PM
soarer479
soarer479's Avatar
do you have a timing light?
Old 07-13-08, 04:52 PM
JspecSC3
JspecSC3's Avatar
Your timing is still off.
Old 07-13-08, 05:34 PM
5sp_jzz30
5sp_jzz30's Avatar
one easy way to make sure that the distributor is on right is to take the cap off and set the motor to TDC on cyl. 1. the rotor should be at the 1 o'clock position...cyl 1 firing.
the timing is about 10* at idle. when i set the timing i made 3 marks. one for 8*, one for stock 10*, and one for about 15* for when i go to the track
Old 07-13-08, 08:53 PM
2jz02
2jz02's Avatar
yea...forgot to mention, car was na-t. took everything apart to smog check...
chuydiaz
06-19-12 09:41 PM
mrlextasy
04-19-12 01:37 PM
OT0814
Florida Lexus Club
03-01-11 10:36 AM
Quick Reply: new to lexus...need help on setting timing.
