Valve after tb is'nt opening up causing reall bad idel
I recently power washed my engine which caused water to stop spark plugs from working after removing the tb and puting new spark plugs in and cleaning them up. My idel is really weird it almost dies I looked at the vacum hose diagram underneath my hood I trided messing with the tps so im stuck what else could be an issue any help woul be greatly apppreciated...
I hope you unplugged the negative b4 washing, and let it dry in the sun with the engine bay open. otherwise, i would check all the electrical connections and sensor plugs around the area. My guess is you got a short somewhere, any engine lights? I would turn on the engine and unplug every possible sensor, you should notice change with unplgging everyone. If not, that's where the problem lies...Hope that helps..
handogg
02-12-13 11:37 AM
Yg_green1
GS - 1st Gen (1993-1997)
09-22-05 02:53 AM
