Best way to flare the fender?
Old 07-21-08, 08:35 AM
tavarish
tavarish's Avatar
Originally Posted by TheRonTom3
yes it will bend and compress that is why you need a stack.
The more newspaper you use the further the fender will be from the tire.
I'll try that.
Old 07-21-08, 10:14 AM
DryBlaze
DryBlaze's Avatar
What offsets are you running? I'm sure you can get away with just a roll.
Old 07-21-08, 08:00 PM
davidv433
davidv433's Avatar
i tried rolling the fenders with a baseball bat, it came out okay but i didnt heat up the paint, now theres paint chips missing on the inside cant really notice it though. i work in hillside right next door.
Old 07-21-08, 11:22 PM
super7star
super7star's Avatar
i got the same problems as well.. this is what i do at the body shop... cut the metal inside the fender and roll that up..
will show u pic once i head to the bodyshop...
Old 07-22-08, 08:55 AM
tavarish
tavarish's Avatar
I have a +38mm offset, but the tires stick out a wee bit more, because they're 285mm width, on a 9.5" wide rim.
I'll try to roll the fenders this weekend.
Old 07-22-08, 12:58 PM
icms001
icms001's Avatar
this is a nice way to flare the rears
Old 07-23-08, 09:14 AM
tavarish
tavarish's Avatar
I'm going to try the newspaper thing this weekend.
Old 07-23-08, 11:13 AM
JspecSC3
JspecSC3's Avatar
You're pulling on a wheel with a 38mm offset? I would just run a 275 and roll the fenders. Pulling is more for those who want the wheel sticking way past the fender like in icms001's picture. You see how far the wheel is sticking out? Thats when I would look into pulling the fender. If you are just doing it for the tire it might look a little funky.
Old 07-23-08, 11:31 AM
chrispy
chrispy's Avatar
What's the point of a 285 on a 9.5? Are you losing traction? And +38 offset would fit with no fender mods. Not telling you to put a 235 on it but a 265 or 275 would be less headache.
Old 07-23-08, 11:43 AM
tavarish
tavarish's Avatar
got the rims and tires mounted, and theyre really good tires. Plus I'm cheap. here's to hoping a fender pull will work, I'm having it done saturday.
Old 07-23-08, 11:44 AM
chrispy
chrispy's Avatar
285's usually aren't cheap. You can replace a tire, but it's gonna cost you to fix a fender if you mess it up.
Old 07-23-08, 11:46 AM
DryBlaze
DryBlaze's Avatar
A pull is probably too extreme for a 38 offset even on a 285. Should be fine with just a roll. Maybe post some pictures of how it looks now.
Old 07-23-08, 11:53 AM
tavarish
tavarish's Avatar
yes, I did have traction issues with 255s in the rear, and I got these 285s for 120 shipped, and they look bad ***.
Old 07-24-08, 08:13 PM
dumdumgreg
dumdumgreg's Avatar
if you do the newspaper thing, show some before/after pics
Old 07-24-08, 08:35 PM
davidv433
davidv433's Avatar
hey tavarish, when you get it done let me know, i wanna look at it.
Quick Reply: Best way to flare the fender?
