NA-T to-------->JDM ARISTO TT SWAP
does anyone know where i can find a write up on swapping a jdm aristo tt in my na/sc300? BUT USING THE JDM ARISTO HARNESS AND JDM ECU???? THANX. Every writeup i have read uses the usdm supra harness and usdm tt ecu. Does anyone have the write up using the jdm components and a write up how to rewire the jdm harness to my 97 sc300 harness, thank you. i have read, but didnt find my answer
I'm doing that as we speak (USDM twins is the only major difference). I bought Phil Auldridge's manual and am sifting through the differences in supra vs. aristo E10 ECU plug and body plugs. I haven't found a specific writeup from absolute start to finish with all Aristo stuff. There is a guy on the forum who did the swap with USDM MAF/ECU and a couple other things but most of the info is applicable. I can send you the pinout for Aristo.
http://lextreme.com/misc1.html
you owe me a beer! j/k
cutting and resplicing the body plugs isnt hard but its time consuming an there is a major likelyness of error.
i kno its 500$ but Dr. Tweak is the man, you will literally drop in your motor and plug and play. also the auto ecu will work with a manual but the CEL will stay lit. good luck, im doing this soon with my sc4
Former Sponsor - Cancelled
Actually there's no reason that you should have a CEL at all, the ECU doesn't throw a code when running manual.
I have no idea why anyone would go out and purchase a Supra harness and ECU and THEN convert that harness to work in an SC. Just convert the Aristo harness and save yourself $700+!!!
-Doc
Kruso
Performance & Maintenance
08-30-13 12:45 PM
