Supra 1jz down pipe
Old 08-01-08, 12:31 PM
ProjectLex
ProjectLex's Avatar
Default Supra 1jz down pipe
Would it at least bolt up to the soarer 1jz? Is there any difference in the engine from these applications?
We can fabricate a pipe to make it work, but I need something that at least bolts up.
Help!
Old 08-01-08, 12:36 PM
DryBlaze
DryBlaze's Avatar
I thought you can use a bpu dp for a mkiv. I got a SP 3" one if you find out if it does.
Old 08-01-08, 01:30 PM
OneJay
OneJay's Avatar
I think gc5ind used an MKIII down pipe and said it bolts up pretty good.
Old 08-03-08, 09:02 PM
ProjectLex
ProjectLex's Avatar
Thanks for the help.
I bought a 1jz downpipe from supra forums and it doesn't bolt up. It was a while back so I have no idea what exactly it was off of. They have a 1jz sell/buy section and that is where I got it from.
There is also a popular 1j dp always being sold on ebay that has the flex section. I bought that and it doesn't bolt up.
I guess I just assumed they both would. Now I am at a loss of where to go. The car is not mobile at the moment so I cannot take it anywhere. My mechanic said he can fab something in the shop but he wants something that bolts up so he has a starting point.
I don't know what to get. We've just been chipping away at the swap but it's near completion so I am getting motivated to get everything I need. If you guys have any for sure's I would definitely jump at it.
Old 08-04-08, 05:17 AM
aka paco
aka paco's Avatar
dang that sucks, i always figured they would bolt up, i figured the only fitment issue was the lower half of the dp, like you would have to get it modified to bolt up to your exhaust.. i almost bought one of those ebay ones too, luckily my 1jz swap already had a 3" dp on it when i picked it up from Jhot
Old 08-06-08, 11:27 AM
ProjectLex
ProjectLex's Avatar
Does anyone have a definitive direction to move in?
1j Swappers - what did you use for a down pipe?
Old 08-28-08, 07:30 PM
ProjectLex
ProjectLex's Avatar
Default If you swapped a 1jz into your sc
What did you use for a down pipe?
Where did you get it? How much did it cost?
Which supra dp will work for a 1j sc?
Does anyone have anything definitive?
Old 08-28-08, 09:14 PM
super7star
super7star's Avatar
someone got to know this... please give us a direction..
i need a dp for my 1jz as well....
Old 08-29-08, 07:00 AM
swaqqa
swaqqa's Avatar
Just goto a Exhaust shop and have them make one, easiest thing to do. The most you'll spend is 100 to get it done? And thats made & installed. Its the Front Pipe that I would order, that yields the most gains out of the engine.
Old 08-29-08, 01:06 PM
Biggu
Biggu's Avatar
i tryed a MKIV downpipe and it deffinitly does not fit! if your feeling like spending some money you can get teh apexi up pipe.
apexi up pipe 145 - T003-7H0917.
and do a cat back exhaust.
if it were me i wouldnt worry about it. i did a 4icnch mid pipe to 3 inch duals and my car put down easily 300 to the wheels. besides the Y pipe is the major restriction on the twins anyways.
Old 08-30-08, 08:10 PM
ProjectLex
ProjectLex's Avatar
Thanks Biggu
At least I am not the only one who has bought the wrong pipe (or 2)
Do you have a link on the A'PEXi? I searched but only came up with
Mitsubishi
145-KM01 Eclipse 1995 - 1999 GSX 60mm-80mm
145-KM02 Eclipse 1995 - 1999 GST 60mm-70mm
145-M005 Evo 8 2004+ 65mm
Nissan
145-N005 Silvia SR20DET 1989 - 1998
145-N001 Skyline 1990 - 1994 GTR (BNR32)
145-N001 Skyline 1995 - 1998 GTR (BCNR33)
145-N001 Skyline 1999 - 2002 GTR (BNR34)
I appreciate the help.
Old 08-30-08, 11:54 PM
1985zcar
1985zcar's Avatar
why don't you just get it up and running and drive it open turbo lolllll
Old 08-31-08, 02:01 PM
Biggu
Biggu's Avatar
Originally Posted by ProjectLex
Thanks Biggu
Mitsubishi
Nissan
i wish i could be more help on it but i cant. only place ive found some are yahoo japan or find some one in japan that has one and will sell you it. i only have the number for the downpipe because my buddy has been searching high and low for it(mind you he is also in japan) so its pretty hard to find.
heres the only one i can find.
http://page17.auctions.yahoo.co.jp/j...=;ipartsmisato
DaBwyan61
13
03-01-18 08:00 AM
jmanhas
01-09-13 11:58 AM
speed6
05-02-10 10:51 PM
scgerg300
08-03-06 07:30 PM
Quick Reply: Supra 1jz down pipe
