head gasket and studs
Old 08-02-08, 10:35 PM
desol11
desol11's Avatar
Default head gasket and studs
wasup guys i am getting all my stuff to go na-t, and i am about to get my head gasket and studs. should i get cometic head gasket and arp studs, gte head gasket and gte studs, or gte gasket and arp studs. what do you guys think is best setup i will most likely be running the t61 about 15psi + thanks
Old 08-02-08, 11:02 PM
mex lex
mex lex's Avatar
I believe you should only use the gte hg only if you have gte pistons. Otherwise, a cometic hg with arp studs.
Old 08-02-08, 11:09 PM
vipsoarer
vipsoarer's Avatar
gte headgasket and arp head studs. It will drop your compression low enough so you can use your turbo at 15+psi. you should be about 9.2:1 i think so you'll be good for about 20psi-ish.
Old 08-02-08, 11:41 PM
yauser
yauser's Avatar
TT HG good for 400rwhp reliably. 2mm good for 450rwhp reliably. 3mm good for up to 600rwhp reliably. These are not facts, Lol.., but just what you see most of.
Cometic, Greddy, etc.. Same sht.
No piston required. TT HG is 1.3 or 1.4mm if I recall, and much thicker than the paper thin GE HG. I think it results into a 9.2:1 c.ratio and it should be good for up to a low boost of 400rwhp reliably. If you want more, do a 1.8mm, or a 2mm 450rwhp. That's hella power already considering you're doing more of city/highway driving.
Your tranny's another issue. What are you planning to do about that?
Old 08-03-08, 02:16 AM
dohc3ltt
dohc3ltt's Avatar
go with hks ,greddy or stock gte headgasket. I've ran 40+psi on a hks headgasket with arp studs.
Old 08-03-08, 08:54 AM
desol11
desol11's Avatar
gte stock and arp sounds good. might pick them up tommarow
Old 08-04-08, 06:44 PM
Jerzy_Boy
Jerzy_Boy's Avatar
are you doing the work yourself?
Old 08-05-08, 01:51 PM
desol11
desol11's Avatar
yes,i do all my work myself. soon i will be doing my auto to manual swap when ever i find a r154
Old 08-05-08, 01:56 PM
FormosaSC
FormosaSC's Avatar
post a DIY on headgasket and arp stud installation if you can, that would be an awsome sticky
Old 08-05-08, 05:13 PM
Jerzy_Boy
Jerzy_Boy's Avatar
+1,000,000,000 I have my car sitting in the yard now waiting for me.
Old 08-05-08, 05:26 PM
PlatanoTLS
PlatanoTLS's Avatar
thats what I have TT headgaskets and arp head studs
Old 08-05-08, 06:43 PM
cbrasian
cbrasian's Avatar
hopefully you have the gte cams or hks 264's..... best of luck to you hope you enjoy the two 90 degree turns to torque it down on all the bolts hopefully you remember to dip the arp studs in oil before you drop em in
Old 08-06-08, 12:09 PM
Gunnar
Gunnar's Avatar
ARP headstuds and GTE headgasket going in here.
You can use oil but I'd suggest using the ARP moly lube that comes with them. The instructions on the headgaskets say you can use either (and offer torque specs for both) but the instructions on the ARP main studs say to only use a moly lube and that oil is not recommended. If they say that for the main studs, I'm going to use it on the headstuds too.
Old 08-07-08, 07:34 AM
cbrasian
cbrasian's Avatar
you can use both i've had the guys from arp over at the shop b4 and they can its fine. moly lube just another way to make a buck..
Old 08-08-08, 09:51 AM
Gunnar
Gunnar's Avatar
It comes in the box with the headstuds and mainstuds...
suprakidxx
13
12-08-19 01:07 AM
MacGyverQu
05-29-14 08:12 AM
2jzcrazy
Suspension and Brakes
04-15-14 05:14 PM
jschru
01-06-14 09:46 AM
MIC123321
GS - 1st Gen (1993-1997)
11-06-06 08:37 PM
Quick Reply: head gasket and studs
